mimsOrbi
May 02, 2019Follower
Armor Blocking Sites - How to Unblock?
How do you allow specific sites that Netgear Armor is blocking?
DexterJB
Aug 12, 2019NETGEAR Moderator
Hi all, for a more detailed description/reason why the sites are being blocked as well as requesting to have it unblocked, it is best to reach out to Bitdefender via their support channels below. Rest assured, your feedback is taken note of and will be passed along to the team.
https://www.bitdefender.com/consumer/support/
Dexter
pizza_pablo
Aug 12, 2019Apprentice
dexter won't turning Armor off, in the smartphone app allow free passage to any web site?
- DexterJBAug 12, 2019NETGEAR Moderator
Hi pizza_pablo, you should not get any prompt that a site has been blocked by Armor if you have the feature turned off. Are you still experiencing the issue?
Dexter
- pizza_pabloAug 12, 2019ApprenticeDexterJB by "should not get any prompt that a site has been blocked by Armor if you have the feature turned off" do you mean that sites will no longer be blocked or that there will be no notice when sites are blocked?
My thermostat cannot get to its Ecobee web site. I am unsure if this is an Armor or Ecobee fault.
My issue is with this Armor blocking sites and having no work around. I also don't like that once I opt in, they're is no way to get rid of it. - DexterJBAug 12, 2019NETGEAR Moderator
Hi pizza_pablo, Armor should no longer block any websites if it is turned off. I have sent you a message. Please check your inbox.
Dexter
