PCoumans
Jan 13, 2022Aspirant
ARMOR extension discount code not working
Hi, I have RBR850 - Orbi Tri-band Mesh WiFi 6 Router(RBR850) mesh wifi system with Netgear Armor subscription. The Orbi app offers 35% discount when extending, but when I click it, don't get the disc...
Jan 14, 2022Guru - Experienced User
You'd have to contact support. Sadly this is the netgear community forum where members of the public help out.
PCoumans
Jan 14, 2022Aspirant
Thank you, would you by incident have a link or email address as I cannot find (after extensive search)...
Many thanks.
Many thanks.
- plemansJan 14, 2022Guru - Experienced User
To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process.
Click on: My Support---->Contact Support---->Get help with my subscription serviceif that doesn't work, you should be able to just go through the standard support process and not through the subscription services option.
