PCoumans
Jan 13, 2022Aspirant
ARMOR extension discount code not working
Hi, I have RBR850 - Orbi Tri-band Mesh WiFi 6 Router(RBR850) mesh wifi system with Netgear Armor subscription. The Orbi app offers 35% discount when extending, but when I click it, don't get the disc...
PCoumans
Jan 14, 2022Aspirant
Thank you, would you by incident have a link or email address as I cannot find (after extensive search)...
Many thanks.
Many thanks.
Jan 14, 2022Guru - Experienced User
To get a hold of support for subscriptions services like Armor/Circle, click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process.
Click on: My Support---->Contact Support---->Get help with my subscription service
if that doesn't work, you should be able to just go through the standard support process and not through the subscription services option.
