GradyG
Jul 24, 2022Follower
armor hijacked my network on cax80
I activated armor and now it is blocking me from aps and about anything. I tried to turn it off but it won't stay off. I followed these steps below and agin it will not turn off. It blocks me from ac...
Aug 01, 2022Guru - Experienced User
Also after you disable Armor in the NH App, be sure to power cycle the modem OFF for 30 seconds then back ON.
Another way to fully disable Armor would be to factory reset the modem and setup from scratch. Just don't re-enable it after setting it up.
