Poison183848
Mar 17, 2023Aspirant
Armor is not activating
I start using Armor on 2/3/2022 it work fine for a year but after the renewal this year it stop working, the app says is activating and when i touch the armor icon it shows this message: CODE:ARM-PYM...
Mar 17, 2023Guru - Experienced User
You'll need to reach out to NG support for help and information regarding this as this is beyond forum help:
Good Luck.
- Poison183848Mar 17, 2023Aspirant
Thank you for your time i have been trying to fix this with the NG support without success for almost 2 months
