TwoDogs22
Mar 12, 2022Aspirant
Armor missing from web interface
I pressed the power button on the router as I was having streaming tv issues and it factory reset. after rebuilding it I've lost my Armor option in the web interface. It's visible in the ios app thou...
- Mar 14, 2022
OK, yeah so you'll need to download the Nighthawk App from the app store.
Netduma-Fraser
Mar 13, 2022NetDuma Partner
Can you just confirm what router you're using please and the firmware version you're on?
- TwoDogs22Mar 13, 2022AspirantNetgear Nighthawk Xr1000
Firmware version V1.0.0.58- Netduma-FraserMar 13, 2022NetDuma PartnerYou can't really change any settings on the interface for Armor, it's all done on the app. You should see a shield icon top right of the interface though, do you see that? If not can you provide a full screen picture please?
Thank you for responding. I haven’t had the router long and am still learning.
I thought I read where the Armor interface was accessible from the web interface as an entry on the left, headed Security.
Is it only accessible from my iPhone app? Or from the Armor web page and App?
See below for what I get when I click on the A. I'm now thinking that's normal based on what I see and your response
Thanks
Mick
