Koesbeenian
Oct 04, 2020Tutor
Armor not visible in app
I have Orbi AX6000 RBK853 (1x router, 2x satellite) purchased in March 2020. At that time, I remember Armor was not yet available for my setup but to be introduced soon. Now I've udated firmware V3.2...
Koesbeenian
Oct 09, 2020Tutor
Unfortunately I can't log into the app now annymore
Login (adding correct email and password)
Verify identity
Code via mail
adding code in app
"Want to add iPhone as trusted device?"
Yes
Unable to add your device
What could cause this?
Koesbeenian
Oct 09, 2020Tutor
Okay, I'm in by selecting "do not trust device". Strange but it worked.
Christian_R Armor tile still not visible.
I'm on firmware version V3.2.16.6_1.4.4, so latest.
- KoesbeenianOct 12, 2020Tutor
Unfortunately my top of the line, state of the art AX6000, RBR850, RBK850 is not listed in this community's subject dropdown.
I think that might be a key reason that I receive so few answers.
No Armor tile in my app.
What I did so far:
- Installed the system in March 2020.
- Didn't pay much attention to all kind of additional settings as I just wanted to have coverage
- Recently, I started to worry about security
- Looked into Armor, should be available for my system
- There should be a 'tile' in the app called security containing Armor; there is no such tile in my app
- Removed the app from my iphone and ipad
- re-installed app on my iphone
- Still no secirity tile, no Armor
Any ideas?
- Christian_ROct 12, 2020NETGEAR Employee Retired
Hi Koesbeenian,
May you factory reset your router and run through the setup assistant again. If your issue persists, may you send me a private message with your email address and serial number for us to check further.
Thanks,Christian
- KoesbeenianOct 13, 2020Tutor
I just found this in another topic:
"Does Armor work when my Orbi or Nighthawk router is in AP mode?
No.NETGEAR Armor is not supported while your Orbi or Nighthawk router is in AP mode. The Armor tile is not visible in the Orbi or Nighthawk app while your router is in AP mode. When your router is in AP mode, it acts as a gateway for other devices to connect to. For example, setting your NETGEAR router in AP mode broadcasts the WiFi of your existing networking hardware."
I guess that's the answer. I have checked with my provider and the 'Fritz!Box 7581 TQ' need to act as the router for their solution. No work arround. That's why my AX6000 RBK853 RBR850 RBS850 is in AP mode and no Armor visible.
