HarpersMike
Mar 18, 2019Tutor
Armor on Orbi RBR50 transfer to correct license
I've been running Netgear Armor on my orbi network using the trial license. Today I bought the full license - which is (unsurprisingly) via Bitdefender. That was fine and I followed the instructions t...
evil_mike
Mar 18, 2019Apprentice
When you buy the Armor license, you'll receive an activation code via email. To apply it, open armor.netgear.com, sign in with your Netgear account info, and then go to My Subscriptions. Click Activation Code and add the code there. Voila!!
- HarpersMikeMar 18, 2019Tutor
That is what I did and it created as a separate subscription. I need to transfer my router between subscriptions.
Netgear also need to fix their armor support.
