HarpersMike
Mar 18, 2019Tutor
Armor on Orbi RBR50 transfer to correct license
I've been running Netgear Armor on my orbi network using the trial license. Today I bought the full license - which is (unsurprisingly) via Bitdefender. That was fine and I followed the instructions t...
WeirdTechnician
Apr 07, 2019Aspirant
Same problem here. Did you find a solution?
- deltagammaApr 08, 2019AspirantUnfortunately, no solution. I even reset the orbi, which seemed like it might help, but nope, still get the login error and cannot change the associated email address.
- DexterJBApr 08, 2019NETGEAR Moderator
Hi all,
This has been reported to the team. I will provide an update to the thread once available.
Thanks,
Dexter
- WeirdTechnicianApr 09, 2019Aspirant
Here is a collection of screenshots showing the problem. In the upper left the two subscriptions are shown. The one with zero devices is the paid one and should by used by the router. The paid subscription is empty (lower left) while the router is still on the trial subscription (see upper right corner). The 145 days remaining looks like if there were 55 days from my returned defective router and 90 days from the replacement unit.
Also both devices are shown in the Armor Portal (lower right corner). Is there a possibility to remove the old device?
Thanks you :-)
