Retired_Member
Apr 01, 2020Armor on Wifi 6 Routers
Hi, I've just bought the Nighthawk RAX80. Are there any plans to activate Armor on the Wifi 6 models? You would have thought so with the cost of them. If so, what's the timescale? Many thanks
Apr 01, 2020Guru - Experienced User
I know they plan on rolling it out to the RAX devices at some point. but I don't know when and netgear doesn't release dates. To many different things impact release dates such as bugs or world issues (covid).
- Retired_MemberApr 01, 2020Do you know this for certain? If it’s in the pipeline I’ll keep hold of it. The thing is, Asus and TP-Link have Trend Micro variants on their Wifi 6 routers. There is no antivirus software included for Mac and PC admittedly but, to be honest, a router level only Netgear Armor would’ve suited me better.
- plemansApr 01, 2020Guru - Experienced User
Do I know 100%? No, I don't. Is it a reliable revenue stream for netgear? Yes it is.
From my experience, they get the basic firmware running decent and then add features.
- AbhayBApr 01, 2020NETGEAR Employee Retired
HI all,
Thank you for your notes. Please stay tuned for some annoucements/releases over coming months to include Armor on WiFi 6 products. As correctly mentioned, the timelines are definitely a bit challenging given the environment but we are making some great progress!
