Anonymous
Apr 01, 2020Armor on Wifi 6 Routers
Hi, I've just bought the Nighthawk RAX80. Are there any plans to activate Armor on the Wifi 6 models? You would have thought so with the cost of them. If so, what's the timescale? Many thanks
Apr 01, 2020Guru - Experienced User
I know they plan on rolling it out to the RAX devices at some point. but I don't know when and netgear doesn't release dates. To many different things impact release dates such as bugs or world issues (covid).
Anonymous
Apr 01, 2020Do you know this for certain? If it’s in the pipeline I’ll keep hold of it. The thing is, Asus and TP-Link have Trend Micro variants on their Wifi 6 routers. There is no antivirus software included for Mac and PC admittedly but, to be honest, a router level only Netgear Armor would’ve suited me better.
- plemansApr 01, 2020Guru - Experienced User
Do I know 100%? No, I don't. Is it a reliable revenue stream for netgear? Yes it is.
From my experience, they get the basic firmware running decent and then add features.
- AbhayBApr 01, 2020NETGEAR Employee Retired
HI all,
Thank you for your notes. Please stay tuned for some annoucements/releases over coming months to include Armor on WiFi 6 products. As correctly mentioned, the timelines are definitely a bit challenging given the environment but we are making some great progress!
- AnonymousApr 07, 2020
Thanks for your reply. Is there beta firmware available for the RAX80 to try?
Many thanks
