Retired_Member
Apr 01, 2020Armor on Wifi 6 Routers
Hi, I've just bought the Nighthawk RAX80. Are there any plans to activate Armor on the Wifi 6 models? You would have thought so with the cost of them. If so, what's the timescale? Many thanks
Retired_Member
Apr 01, 2020Do you know this for certain? If it’s in the pipeline I’ll keep hold of it. The thing is, Asus and TP-Link have Trend Micro variants on their Wifi 6 routers. There is no antivirus software included for Mac and PC admittedly but, to be honest, a router level only Netgear Armor would’ve suited me better.
Apr 01, 2020Guru - Experienced User
Do I know 100%? No, I don't. Is it a reliable revenue stream for netgear? Yes it is.
From my experience, they get the basic firmware running decent and then add features.
- AbhayBApr 01, 2020NETGEAR Employee Retired
HI all,
Thank you for your notes. Please stay tuned for some annoucements/releases over coming months to include Armor on WiFi 6 products. As correctly mentioned, the timelines are definitely a bit challenging given the environment but we are making some great progress!
- Retired_MemberApr 07, 2020
Thanks for your reply. Is there beta firmware available for the RAX80 to try?
Many thanks
