Retired_Member
Apr 01, 2020Armor on Wifi 6 Routers
Hi, I've just bought the Nighthawk RAX80. Are there any plans to activate Armor on the Wifi 6 models? You would have thought so with the cost of them. If so, what's the timescale? Many thanks
Shawnm
Aug 29, 2020Aspirant
Is Netgear armour being planned for CAX80 modem router?
Aug 29, 2020Guru - Experienced User
I'd imagine so since its a revenue stream for netgear/bitdefender. I know its been added to some the RAX devices (higher end) . The CAX80 was the most recently released device and its usually a bit after rollout that armor gets released.
- ShawnmAug 29, 2020AspirantDo u think it’s better to keep my cable company’s modem Putting it in bridge mode and get the RAX version instead so that I can have it? Would I lose any features by not going with the all in one?
- plemansAug 29, 2020Guru - Experienced User
Shawnm wrote:
Do u think it’s better to keep my cable company’s modem Putting it in bridge mode and get the RAX version instead so that I can have it? Would I lose any features by not going with the all in one?that's up to you to determine. If the whole reason you're getting rid of your providers device is so you're not renting a device from them, it kind of nulls that purpose.
but you could get your own router and then modem.
Or if you got the CAX80, wait a bit, its more than likely trickling down the pipe :)
