konabob
Jul 15, 2019Guide
Armor paid subscription - unable to activate on RBR50 router
I purchased Netgear Armor security after about two weeks of trialing the product. When I login to the RBR50 router from my PC it says "Security Status Not Activated". When I login to the Orbi App fro...
Holybird
Jul 18, 2019Initiate
Bitdefender got back to me and did something on their side. I was able to restart the trial which immediately switched over to my subscription. Bear in mind this was after a full factory reset at the latest firmware. Both my orbi app and web portal are reporting an active subscription now.
konabob
Jul 23, 2019Guide
My Netgear Armor subscription has been activated. I received this email from Bitdefender support after Dexter got involved after seeing my post in this forum. Thank you Dexter and Alina from Bitdefender.
Dear Bob,
Thank you for your patience and please accept our apologies for the delay in our reply.
Please note that we have made some adjustments on your account and you should now be able to see your active Netgear Armor subscription.
Let me know if everything is OK. Have a lovely day!
Best regards,
Alina Bizga
Bitdefender Support Team
- gagarzacSep 21, 2019Aspirant
Hello Dexter & Alina:
I would like to get some help, I've started the trial period on my R8000 router and had to factory reset it, now I can't activate the netgear armor, sent a ticket to bitdefender and so far I got a response stating that i had to re-reset it, and I did.
But the problem still is there, the Nighthawk app on the iphone as well as via the routerlogin.net page says that "An error has occured", Sent the screenshots of both ways to bitdefender about 15 days ago and I'm not getting a response so far, I guess they just dropped on me.
Any help?
- konabobSep 21, 2019Guide
Hello gagarzac, I recommend you send DexterJB (a moderator on the forum) a private message. Include the serial number of your router and your help ticket number with Bitdefender, along with the description of the issue
https://community.netgear.com/t5/user/viewprofilepage/user-id/266983
Good luck. Bob.
