BeachSnoopy
Dec 11, 2023Aspirant
Armor removal
So I don’t see many replies to anything, but how does one remove the Armor service? Just need to call? We have had issues since install and don’t have 6 hours to spend on the phone w a service guy to...
Dec 15, 2023Guru - Experienced User
With in the Orbi or Nighthawk app, you can disable it.
To stop the subscription, you'll need to contact NG support or try here:
To remove it from a router, you'll need to factory reset the router and setup from scratch and use a wired PC and web browser to set it up. Avoid using the mobile apps to set up the router as they may re-enable Armor during the setup routine there.
- BeachSnoopyDec 15, 2023Aspirant
And why is this so invasive and not allow you to control? I’m not crazy Facebook, but since I did this I can hardly even check Facebook or my car pages…like this Netgear deal is blocking me???
