WRSORBI
Nov 15, 2023Luminary
Armor reporting issue after upgrading to firmware
I am having the same Armor reporting issue after upgrading to firmware V7.2.6.21_5.0.20. Issue did not exist in prior V6.3.7.10. No change in notification settings occurred (verified) yet Armor repo...
Nov 16, 2023Guru - Experienced User
Something to file a bug report about:
Or make contact with NG support about:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
- WRSORBINov 16, 2023Luminary
No problem. Case number just opened is 47805969
- FURRYe38Nov 16, 2023Guru - Experienced User
Let us know how it turns out.
- WRSORBINov 20, 2023Luminary
Resolved. Although a factory reset was requested by support and performed, the probable real fix was the subsequent disabling/enabling all notifications for the Orbi app in IOS settings. Armor then reinitialized the log and recalculated the security score.
