WRSORBI
Nov 15, 2023Luminary
Armor reporting issue after upgrading to firmware
I am having the same Armor reporting issue after upgrading to firmware V7.2.6.21_5.0.20. Issue did not exist in prior V6.3.7.10. No change in notification settings occurred (verified) yet Armor repo...
WRSORBI
Nov 16, 2023Luminary
No problem. Case number just opened is 47805969
Nov 16, 2023Guru - Experienced User
Let us know how it turns out.
- WRSORBINov 20, 2023Luminary
Resolved. Although a factory reset was requested by support and performed, the probable real fix was the subsequent disabling/enabling all notifications for the Orbi app in IOS settings. Armor then reinitialized the log and recalculated the security score.
- FURRYe38Nov 28, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- WRSORBINov 30, 2023Luminary
Still having issue and working with Netgear
