Rmalibu
May 25, 2022Star
armor security and need to add the bit defender
On my orbi 853 had the trial armor security and when tap the security panel it lets me know that bitdefender can be added to 11 devices on my system and if i click on install i am asked to get the ...
Rmalibu
May 26, 2022Star
So Bitdefender then via their app get installed on those devices and acts as virus malware protection? Much like say avast or similar products? So if you have something like that say on a computer or iPad why would you need Bitdefender
May 26, 2022Guru - Experienced User
You'd have to check with the specifics of the program you install on your device for what it actually protects against.
