plemansGuru - Experienced UserJun 23, 2020To fully remove it? Downgrade the firmware to a version before armor. Otherwise its built into the firmware and you can just not enable it but you can't "remove" it.
JLW01Aspirant to plemansJun 24, 2020Hi plemans, Thank you for this. How do I disable it or will it disable itself at the end of the trial period?plemansGuru - Experienced User to JLW01Jun 24, 2020https://kb.netgear.com/000060900/How-do-I-turn-NETGEAR-Armor-on-or-off-using-the-Nighthawk-or-Orbi-app
