JLW01
Jun 23, 2020Aspirant
Armor Security
How do I remove the Armor Security product
Jun 23, 2020Guru - Experienced User
To fully remove it? Downgrade the firmware to a version before armor.
Otherwise its built into the firmware and you can just not enable it but you can't "remove" it.
