s3v3n
Mar 09, 2023Tutor
Armor showing inactive subscription
 Hello,    I was told to reach out to you as my Neatgear Armor is showing disabled on the Orbi app, however my subscription is active.    There was an initial issue where I was charged twice and when ...
- Mar 10, 2023You'll need to contact NG support as this is beyond forum help: https://community.netgear.com/t5/NETGEAR-Armor/Armor-Help-and-Information/m-p/2211063#M6089 Good Luck.
s3v3n
Mar 09, 2023Tutor
Hello,
There was an initial issue where I was charged twice and when that issue was corrected, I now experience this issue with the app.
However, when I click subscription via the app, it shows my active subscription, however I cannot access the GUI as it shows my subscription expired and asks me to sign up.
Mar 10, 2023Guru - Experienced User
Good Luck.
