erock82
May 09, 2019Guide
Armor slows internet speed drastically
HI, I just installed the Netgear Armor on my RBK50 router. I noticed the internet seemed to slow a lot. I ran on speed test on a few connected devices and got ~10Mbps consistently. I have a 150 Mb...
erock82
May 15, 2019Guide
Hi DexterJB,
Yes, I am still having the extremely slow internet speeds. Been a busy couple of days hopefully I'll get to deactivating armor tonight and see if that is the problem. Not sure how it isn't that this point...
- DexterJBMay 15, 2019NETGEAR Moderator
Thanks for responding. Please keep us posted for us to provide a recommendation.
Dexter
- erock82May 17, 2019Guide
Hi DexterJB,
I disabled armor but still the same issue. Maybe the firmware update caused the slow down? Or maybe armor is still running in the background? The interface isn't the best and I don't trust that armor has actually been disabled.
- DexterJBMay 19, 2019NETGEAR Moderator
Thanks for the update. As a way to isolate the issue, please try resetting the router back to factory defaults and check if the issue will persist. You can back up the router settings in case you'd want to restore it. However, it is recommended to reconfigure everything instead as a way to avoid any lingering issues to be carried over.
Dexter
