SilentService
Jun 07, 2019Star
Armor subscription activated but not not applied to RBR50
I bought a subscription and during activation was presented with a very confusing dialog and apparently chose poorly. The activation was accepted, but the RBR50 is still running on the trial. See s...
SilentService
Jun 17, 2019Star
Hi Dexter,
Armor is NOT active on my router as screenshot shows. Subscription shows active on zero devices. Pls advise,
Rob
DexterJB
Jun 17, 2019NETGEAR Moderator
Hi SilentService, does the router UI and/or the Orbi app show that your Armor subscription is active?
Dexter
- SilentServiceJun 18, 2019StarHi again. The Orbi app security panel says expired. I can’t attach screenshot because suddenly .jpeg files are not accepted as a valid attachment type.
- SilentServiceJun 19, 2019Star
Here is the screenshot I was unable to attach earlier
- DexterJBJun 26, 2019NETGEAR Moderator
Hi all, other users have reported that Bitdefender was able to fix it for them. Also, NETGEAR engineering was already made aware and are looking into it. For a more immediate resolution, you can contact Bitdefender on the link below or make a follow up if you have an existing ticket.
https://www.bitdefender.com/consumer/support/
Dexter
- Retsailor2009Jun 26, 2019StarThanks for the info Dexter.
- DexterJBJun 19, 2019NETGEAR Moderator
Hi SilentService, thank you for responding. Please make sure that the credentials that you've used for the trial is the same as the one you've used when you subscribed. Also, what happens if you go and select Renew Your Subscription and senter the activation code that you've received?
Dexter
- Orbi-RocJun 21, 2019Luminary
HI DexterJB . You know, and I know you do, there has been so many posts from user experiencing difficulties transitioning from TRIAL to PAID that one must wonder: DOES BITDEFENDER REALLY WANT US TO BUY INTO THIS OR NOT? Becausea if they do, they better get their act together PDQ and facilitate the process! Honestly Dexter, I've never, but NEVER seen anything like this. No matter how technically-able a company is, if it can't handle something as simple as to ACCEPT a PAID subscription to their product, then they have a real problem, don't they?
