ACR85
Sep 25, 2022Follower
Armor Subscription not Showing APP
Hi Netgear Community, I've received a notification email from Netgear saying that my Armor subscription for my RAX50 was coming to renewal date soon (19-Oct-2022). My product (the only Netgear o...
C1bear
May 28, 2023Aspirant
I'm having same issue on my app for my RAX50 ive contact tech support 4 time's its been 2 weeks now smh
- CarlosFuAug 05, 2023Aspirant
I have the same issue on my Netgear router.
Does someone had a solution from Netgear support team?
Best regards.- markrothSep 28, 2023Tutor
1st screen2nd screen showing failure
RBR50v2 — Orbi AC3000 Tri-band WiFi Router
IOS app for ORBI is having same problem as above in regards to showing Armor as if it does not exist as an active subscription. This is a major issue because the web UI for Orbi won't let you do anything security related and says you have to use the mobile app.
