Piggington
Mar 08, 2023Guide
Armor subscription transfer from broken ORBI to replacement ORBI PENDING
In January 2023 my Netgear Orbi RBR50 broke and I bought a replacement ORBI RBR50v2. I had active subscription on Netgear ARMOR on my old broken ORBI and I contacted NETGEAR technical support to t...
- Mar 22, 2023
Update: Yesterday, March 21st, I got a call from Netgear informing that my ARMOR subscription has finally been transferred from broken ORBI to its replacement.
Anyway, I have now cancelled my automatic ARMOR subscription renewal and will start using Firewalla instead.
Mar 10, 2023Guru - Experienced User
You'll need to contact NG support as this is beyond forum help:
https://community.netgear.com/t5/NETGEAR-Armor/Armor-Help-and-Information/m-p/2211063#M6089
Good Luck.
Piggington
Mar 13, 2023Guide
Yes, I have contacted the tech support back in January 2023. A ticket was filed and no luck ever since.
I just called the tech support again today. A guy based in Philippines mentioned that my case was escalated to "product support team" in 2/27/2023. I told him that I filed my ticket in January 13th. I asked why the case was escalated like more than one month - he could not answer.
- PiggingtonMar 22, 2023Guide
