Wxman38
Dec 06, 2022Guide
Armor support
I tried to talk to someone in support about the problems their Armor program is causing some sites to not be able to connect without having to reboot the router. Unfortunately, every time I reached ...
- Dec 06, 2022
Again, armor is baked into the firmware. But if something didn't get disabled properly when you turned it off, it can help.
Dec 06, 2022Guru - Experienced User
Wxman38
Dec 07, 2022Guide
Tried the factory reset today. First thing I noticed from yesterday was the Nighthawk app kept indicating no internet connection.
After the factory reset, I ended up seeing the Nighthawk app when I tried to set up to my settings. It doesn't give you a choice about Armor. In order to proceed, you have to accept it. However, after the reset, I restored my cfg file, and was back in business.
Now when I look at the Nighthawk app on my phone it shows I have an internet connection. It also shows Armor enabled and activated.
At the moment iTunes and the other software problems seemed to have stopped. However, since they used to come back after a few hours I won't know if the reset did the trick. Hopefully the reset worked. Thanks.
