wsakin
Nov 16, 2023Aspirant
Armor thinks IOS notifications are disabled
I am having the same issue on mine. i guess it's not really hurting anything but it's just annoying to see the security score drop each day because of this when i'm clearly getting notifications.
Nov 20, 2023Guru - Experienced User
Does this happen with the MAC address randomizer disabled on the phone?
wsakin
Nov 20, 2023Aspirant
I will disable this feature for my home wifi network and test it out but this setting is different from network to network and doesn't apply when on cellular data.
- FURRYe38Nov 20, 2023Guru - Experienced User
What NG router model system do you have?
What FW version is loaded on it?
What Apple device model do you have and what iOS version is loaded on it?
- wsakinNov 20, 2023Aspirant
Nighthawk RS700
v1.0.7.80
iPhone 15 Pro, 17.0.2
Is this version a Beta you got from NG support?
That version of FW has not been officially released...If so, then something to let NG support know about as I presume it may not be fully yet tune in between it self and Armor. Something NG will need to address.
