Jeffgear
Dec 29, 2022Virtuoso
Armor thinks iOS Notifications were always disabled
The Orbi app Security score has been gradually decreasing over the previous week as it's convinced iOS Notifications are disabled - see screen capture. Toggling them off and back on for both the Orbi app and Armour app doesn't fix it. Nor does rebooting the iPhone. The Armor/Bitdefender app dashboard reports everything is green. What seems to have resolved it is actually logging out of the Armor/Bitdefending app, then logging back in. The the score reverted to 84. It's not in the 90s as the app still has the long-running unresolved issue where it thinks my 6 iOS devices are not running Armor/Bitdefender when in fact they are, whereas the MacBook Pro is reporting as protected.
1 Reply
- JeffgearVirtuosoI logged this as a bug direct with Bitdefender as it reoccurs. Logging back into the iOS Bitdefender app seems to only be a temporary fix for a few days, then the Orbi Security feature thinks you have notifications disabled again.
