Gminn
Dec 07, 2021Aspirant
Armor VPN limit and mobile security
Using Netgear Armor on RBK40 and iPhone 12, iPad 9th Gen. When using the VPN on mobile devices it seems when you hit the 200MB limit the VPN will disable. And since Web Protection is depending on V...
HTJ
Dec 10, 2021Initiate
I had the same issue with the "A" "Bitdefender" app. I purchased a subscription for the premium VPN service and I downloaded the "VPN Bitdefender" app (both black logos in the App Store not the red Bitdefender). Now I get the unlimited bandwidth on the VPN, but the web protection is not showing that it's on. To get that to work I need to go back to the "A" "Bitdefender" and then I'm back to the 20MB limit. I've found that calling Bitdefender is better than calling NETGEAR for service on these things. Bitdefender has a NETGEAR desk.
