ScottBLA
Apr 11, 2022Guide
Armor vulnerability scan fails
Armor vulnerability scan found a vulnerability on an IoT device back in Feb. I undated the firmware on the device. I’ve tried to rescan multiple times over the last two months, but it says fails to co...
DexterJB
Apr 14, 2022NETGEAR Moderator
Hi ScottBLA, you can always reach our support team via the link below if you need any technical assistance with your NETGEAR device.
https://www.netgear.com/home/contact-us/default.aspx
You can also call the number below.
1-888-NETGEAR (1-888-6384327)
Dexter
NETGEAR Team
- ScottBLAApr 18, 2022GuideI was able to resolve the issue working with Netgear support. I was instructed to go th the website and download the latest firmware which I then manually installed and it fixed the issue. The frustrating part was the app had been telling me my firmware was up to date for many months even though it wasn’t. So, lesson learned is don’t trust the “Check for Updates” function in the Orbi app as it doesn’t work and says, “No new firmware is available at this time” even when I was several versions behind.
