LeeH21's avatar
LeeH21
Tutor
May 20, 2021
Armor Vulnerability Scans Constant Notifications
I just started trying the Armor and I am getting constant notifications on device vunerability scans with no issues.  I thought it might just need to scan each device once but it's scanning them over and over.  I would WANT to be notified if it found something but I don't need constant notifications that there are no issues.  Is there a way to set the notifications you receive to only be with issues?  My phone is literaly going off every 3 min or so with a new scan.
  • Never mind.  After about 4 hours it stopped and only goes off when something new connects.  I guess I just didn't give it enough time to get caught up. :)
    • Christian_R's avatar
      Christian_R
      NETGEAR Employee Retired
      Hi LeeH21,
      Thanks for providing an update on your post as it may possibly help others in the future.
      Christian
