edjenn1998
Sep 07, 2020Aspirant
Armor Will not activate
Armor will Not activate. I gave up on phone support after waiting for too long to get a person to help. I used the chat support and I was told to basically unplug the router for 2 min and restart it ...
edjenn1998
did not work. It was off so I turned it on and then back off. No good. I trying it on. no good.
Sep 07, 2020Guru - Experienced User
Did you try contacting bifdefender support (what armor's based on) at all?
https://www.bitdefender.com/consumer/support/
You can also try a factory reset of the router and reinstalling it.
Are you using the app for setup?
- edjenn1998Sep 07, 2020Aspirant
I have reset the router. I have contacted Bitdefender, they wanted me to buy a subscription. I still have the message stating that Armor is not activated. When I try to activate it It times out and I get a message saying that it took too long and try again. I will not pay for a subscription for a service that can not be demonstrated that it will even work. Resetting the router did nothing. Turning remote management on/off/on and so forth did nothing. Calling the customer support line only to wait soo freaking long that I just hang up because I think it rediculous to have to be on hold that long. So far I am not impressed by Netgears customer support. I have also done the chat support option.
- michaelkenwardSep 08, 2020Guru - Experienced User
- Christian_RSep 08, 2020NETGEAR Employee Retired
Hi edjenn1998,
May you send me a private message with your email address and serial number for us to check further. And if you've contacted our support team, please provide your case number(s).
Thanks,
Christian
- smithgroupJan 09, 2021Aspirant
Did you get this resolved? If so, how?
Thanks!
