Mrosent
Oct 18, 2020Follower
Armor won’t install on router
I purchased armor and activated in the armor web portal. I can successfully log into the armor portal and install protection on my devices When I attempt to activate armor in the nighthawk app it only offers the free trial. I’ve attempted a factory restore with no success. Please help.
- Christian_RNETGEAR Employee Retired
Hello Mrosent,
Welcome to the community! May you send me a private message with your email address and serial number for me to check further.
Thanks,
Christian
- PistoleGuide
Hi Christian,
I have exacly the same problem.
About 51 hours ago I bougt a subscription. I can install it on my mac without a problem.The software on my Rax120 doesnt activate.
I have toggled extern management on the router and serveral reboots without succes.
I will sent you an pm with my emaliadres and serialnumber of my RAX120. Can you please loook in to it?
Grtz Paul
- jeffs143InitiateI have the same problem. Only a button to try the trial and then an error saying it couldn't be installed.
- Emmarose12Aspirant
had the same issue back in those days when I got in touch with these type of routers, those were hectic days solved issues like daily jumble answer for gaining my confidence back.
