CR-sound
Mar 24, 2021Aspirant
Armour added to existing rbr50...how to install?
I have an rbr 50; just bought an Armour subscription. My firmware is up to date. Is there a manual install procedure for the rbr50? Buying a product with no manual is really an experience that mit...
Mar 24, 2021Guru - Experienced User
did you get an activation code?
How do I activate my NETGEAR Armor subscription using an activation code? | Answer | NETGEAR Support
You can find manuals on the support site.
Orbi RBR50 | WiFi System | NETGEAR Support
- CR-soundMar 24, 2021Aspirant
Yep, I got a code and activated. The process described online assumes the purchase of a new router setup. I see no instructions for adding to an existing setup router with current firmware. I would like an Armour manual; I have what I need for the router.
one more detail...my Orbi app does not show a security tab and does not show that it needs an update in the PlayStore
- Christian_RMar 24, 2021NETGEAR Employee Retired
Hello CR-sound,
May you send me a private message confirming your router serial number and email address for us to look into this further.
Thanks,
Christian
