Purigading
Aug 09, 2020Aspirant
Armour Seccurity and Orbi
I have model (RBK50) AC3000 , which I could not locate in the pull down windows when typing this so just selected anything to get things moving. But it is a (RBK50) AC3000 with 3 satellites. I ha...
CrimpOn
Aug 09, 2020Guru - Experienced User
Purigading wrote:
Since installing the Armour Security with Bitdefender in my Android phone the Orbi app shows only the Orbi main router in green - but the 3 satellites are all in red. Is this supposed to be so? No. This should not happen.
Next, I tried to disconnect the "security" on the mobile phone app (android) in settings/security but all I get is "disabling NETGEAR armour", and then it times out without completing the disconnection. I tried many times, same all the time.
"Armor" is what Netgear means by "Security" in the Orbi "app". Similar to the way "Parental Controls" means "Disney Circle".
Questions about the Orbi "app" often get a more informed response if you post in the Netgear community forum devoted to the app:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-pro-wifi
Not having ever activated Armor myself, I have a suspicion that "something is messed up" between your Orbi and the "app" and the only way to correct things is to do a "Factory Reset" and set it up again. Next time, you might be better off to say, "No Thanks" to Armor.
Maybe someone in the App forum will have a better suggestion.
Purigading
Thanks ...factory reset of the Orbi or my main router? Is the software for Amour inbedded in the Netgear app....and will always be there until it is removed or expired? Cheers Gerry
- MstrbigAug 09, 2020Master
Purigading wrote:
Thanks ...factory reset of the Orbi or my main router? Is the software for Amour inbedded in the Netgear app....and will always be there until it is removed or expired? Cheers GerryHopefully factory resetting the Orbi router fixes it.
- CrimpOnAug 09, 2020Guru - Experienced User
Purigading wrote:
Thanks ...factory reset of the Orbi or my main router? Is the software for Amour inbedded in the Netgear app....and will always be there until it is removed or expired? Cheers GerryBitdefender Armor includes software for individual devices (PC's, Mac's, etc.) and also software that runs on the Orbi router. It is the router software that appears to interfere with what people want to do. It also scans devices on the local LAN to discover "vulnerabilities". This is the phenomenon that causes some laser printers to spit out three pages once a week when the Armor probe does (God knows what) when connecting to the printer.
I do not think there is any actual "Armor Code" embedded in the Orbi "app" because many users leave their Orbi app turned off for hours at a time (days? weeks?). Can't do much if the app isn't running.
The thing I (personally) find most annoying is that there appears to be no method to disable Armor from the web interface, only using the "app". So a customer who gets sucked into "Activate Armor NOW" when setting up their Orbi using the web interface has no way to turn it off besides doing a Factory Reset or installing the app they never wanted in the first place.
Sorry to rant.
NETGEAR Armor™ protects your smart home and private information from internet threats. Multi-layer cyber security is built into your WiFi router to secure an unlimited number of devices on your home network, like your smartphone, laptop, baby monitor, smart fridge, and more. Includes Bitdefender Security to provide anti-virus and anti-malware protection, and Bitdefender VPN for secure internet browsing using an encrypted connection for Windows, MacOS, Android, and iOS devices.
