Tico_Man
Aug 18, 2022Aspirant
BATTERY THIRSTY ARMOR-BITDEFENDER VPN BLOCKS INTERNET WHILE ON CELLULAR NETWORK
Hi Folks, It seems like it's impossible to disable ARMOR VPN without losing access to the internet while on cellular network. Let me explain a little more: My nightmare started when I noticed ...
michaelkenward
Aug 18, 2022Guru - Experienced User
This happens on a particular Netgear device? They aren't all the same.
Armor has its own bolt hole:
NETGEAR Armor - NETGEAR Communities
You might do better to try there.
Tico_Man
Thanks I'll try there.
BTW I have a MK62 Nighthawk Mesh System at home, but this issue is limited to my iPhone which has the nighthawk app on it.
