rgpriest
Jun 12, 2021Aspirant
Bitdefender Armor and System Mechanic
HAs anyone had any experience runnig Armor, Bitdefender and iolo's System Mechanic Ultiate Defense?
- Jun 18, 2021
Hello rgpriest,
We are not aware of any issues regarding NETGEAR Armor and System Mechanic. However, if you do run into any issues I would recommend contacting our support team using the link below as newly purchased devices are provided with 90 days of complimentary support.
https://www.netgear.com/support/contact.aspx
Christian
rgpriest
Jun 17, 2021Aspirant
I recently purchased the Nightwhaw router/satellie system MS 63 i believe as well as the Nighthawk Telephony Modem. I was looking to install Armor and Bitdefender on our devices. Some of our laptops have iolo System Mechanic Ultimate Defense. I know that runnig two security programs can cause conflicts so I wanted to see if I should remove System Mechanic before running Bitdefender
Christian_R
Jun 18, 2021NETGEAR Employee Retired
Hello rgpriest,
Christian
