StLFan
Aug 24, 2022Guide
Bitdefender blocking malicious host on iPads
Hello, I have an Orbi RBR40 with 3 satellites. Netgear Armor with bit defender/VPN installed on iPads. In the last 2 weeks, I’ve started getting warnings that ‘malicious host blocked on iPad’ f...
Aug 25, 2022Guru - Experienced User
If you're getting the reports daily, shut off your devices and only use 1. Watch for the notices. That'll help you narrow it to a specific device.
From there you can work on seeing if something on it is causing it. It could be something on a site you go to or even an app that does have something nefarious in it. Tough to know with the info you've given.
- StLFanAug 25, 2022GuideI’ve done that. It seems it happens when either iPad is asleep and plugged in, usually within 10-25 mins. Infrequently, I get a message that ‘Page was blocked. The page you were trying to access was dangerous and was blocked for your protection.’ This is while the iPad was asleep and plugged in early this morning.
- plemansAug 25, 2022Guru - Experienced User
You can go into armor and see what sites are being blocked.
https://kb.netgear.com/000061032/NETGEAR-Armor-is-blocking-URLs-that-I-want-to-access-what-do-I-do
It also has more info on why it was blocked.
It could be an app in the background updating its connection and that being an issue
- StLFanAug 25, 2022GuideI have looked at that in bitdefender (nighthawk not available for my router), the sites listed are classified as malicious (one in the Netherlands the other Iceland). I actually had one alert pop up while I was using the iPad. I’m testing now by having no email and no safari cache/websites on one iPad. Curious if it’s a spam email undeleted from junk and trash folders that may have some JavaScript or something triggering the call to these websites. I’ve also turned off background app update for all but a few key apps.
