pgbachman
Oct 27, 2022Aspirant
Bitdefender currently supplied by Netgear does not support macOS Ventura. When update?
Greetings. Just updated one of my Macs to macOS Ventura. Current update of Bitdefender supplied by Netgear through autoupdate is 8.4.0.36. Current version, according to the Bitdefender support site i...
Topology
Jan 02, 2023Virtuoso
Dougcjohn, to clarify, are you saying that the older version of Bitdefender Antivirus for Mac supplied by NETGEAR Armor cannot be successfully installed on M1 hardware with macOS Ventura 13.1, and therefore cannot be manually updated to the most recent version available directly from Bitdefender?
SERASolutions
Jan 02, 2023Initiate
I can confirm that on a new Macbook with M1 running Ventura 13.1 I am unable to complete the install using the Netgear Armor version of Bitdefender.
When I had Bitdefender installed on another Macbook Pro with M1 but upgraded to Ventura in continued to work. A fresh install however does not appear to work with the current version. Very frustrating and will cancel if they cannot resolve it asap.
