pgbachman
Oct 27, 2022Aspirant
Bitdefender currently supplied by Netgear does not support macOS Ventura. When update?
Greetings. Just updated one of my Macs to macOS Ventura. Current update of Bitdefender supplied by Netgear through autoupdate is 8.4.0.36. Current version, according to the Bitdefender support site i...
NNB
Feb 03, 2023Initiate
Im having same issue.. The software direct from Bitdefender installed ok.. But Netgear version does not... Has anyone had any success on Ventura ?
saalmans
Feb 09, 2023Aspirant
Just discovered this after unboxing my new M2 MacBook Pro - very disappointing Netgear. We have paid for this software and we are running a common OS & device.
Is there any official update on this?
- TopologyFeb 10, 2023Virtuoso
It appears that the general issue of NETGEAR failing to supply the current version of Bitdefender Antivirus for Mac (9.2.0.12) is well-known, and a (hopefully temporary) workaround solution is to purchase a license for that product directly from Bitdefender. Please see the recent posts in this thread.
- pgbachmanFeb 11, 2023Aspirant
Thanks to Topology for the previous response.
It sounds like this comes down to a licensing issue between Netgear and Bitdefender.
- Netgear Armor provides Bitdefender 8.x (currently Version 8.4.0.36 on my Macs) for installation on devices
- Bidefender purchased directly from the manufacturer is a 9.x version
- It isn't clear whether Netgear Armor actually includes Bitdefender running in the routers or simply checks for installation on clients and notifies when it isn't installed and when the client-side software detects an issue.
This raises some questions:
- WHY is Netgear Armor providing an older (outdated?) version of Bitdefender?
- WILL Netgear begin providing the current release of Bitdefender as part of the Armor subscription and when?
- Has anyone received an answer from Netgear to these two questions?
Based on the answers to these questions I could determine whether it will be worth renewing Armor when the subscription comes due or choosing another solution.
