Chris_SA
Sep 03, 2019Follower
Bitdefender Netgear Armor mobile app vs Bitdefender Mobile Security
The Bitdefender mobile app deployed by Netgear Armor appears at face value to have very limited functionality compared with the Bitdefender Mobile Security App. It's not clear whether the Armor Bitde...
DexterJB
Sep 04, 2019NETGEAR Moderator
Hi Chris_SA, welcome to the community! Thanks for your great question! There is no need for you to have a separate antivirus for your mobiles and home computers since the NETGEAR Armor Bitdefender Total Security is already part of your subscription and functions as the local protection for your devices. The links below may help.
How is my NETGEAR Armor subscription different from the Bitdefender Total Security 2019 subscription?
What is the NETGEAR Armor Bitdefender Total Security feature?
https://kb.netgear.com/000059440/What-is-the-NETGEAR-Armor-Bitdefender-Total-Security-feature
How do I install Bitdefender local protection from the Nighthawk app on my iOS device?
How do I install Bitdefender local protection from the Nighthawk app on my Android device?
How do I install Bitdefender local protection on my macOS device?
https://kb.netgear.com/000059549/How-do-I-install-Bitdefender-local-protection-on-my-macOS-device
How do I install Bitdefender local protection on my Windows device?
https://kb.netgear.com/000059453/How-do-I-install-Bitdefender-local-protection-on-my-Windows-device
Dexter
