Orbi-Roc
May 11, 2019Luminary
Bitdefender Total Security vs Netgear Armor
In this link https://kb.netgear.com/000059440/What-is-the-NETGEAR-Armor-Bitdefender-Total-Security-feature, it says that Bitdefender Total Security features the following:
Anti-ransom softwa...
- May 11, 2019
Good day schumaku and thank you so much for the prompt response to my post. But I am still not all that clear on (A) Netgear Armor alone vs. (B) Netgear Armor + Bitdefender Total Security, when dealing with iOS, OSX, Windows and Android devices when connected to the Orbi router.
What features does (B) offer that I don't get in (A)?
For example, both my wife and I have MacBook Pros running the latest OS X version. We do not have Bitdefender Total Security installed; and yet, Netgear Armor caught a physing URL on my wife's MacBook. So Netgear Armor, on its own, does protect. What I have yet to understand is what exactly does it do; and what additional protection, if any, do I get by installing Bitdefender Total Security (while devices are connected to the network via the Orbi router)?
If Netgear Armor blocks ALL incoming threats and performs a bona fide vulnerability assessment on the Netgear router, then what is the value-added of installing Bitdefender Total Security on devices that will only be used on the Orbi WiFi network?
Orbi-Roc
schumaku
May 11, 2019Guru - Experienced User
Unless it's a plain text (http) communication, the software running on the router (as part of the Netgear Armor offering, also provided by Bitdefender), will only be able to detect the DNS domain lookup (name -> IP address) and/or the communication with an IP address known to be used for phishing.
For anything beyond, there is no other way but the deployment the Bitdefender software to all clients.
- Orbi-RocMay 11, 2019Luminary
I don't know what went wrong here schumaku but I did mark your last message as the solution ... and the system gave it to me instead. Perhaps a moderator will find a way to correct this. This is the solutiion:
Re: Bitdefender Total Security vs Netgear Armor Unless it's a plain text (http) communication, the software running on the router (as part of the Netgear Armor offering, also provided by Bitdefender), will only be able to detect the DNS domain lookup (name -> IP address) and/or the communication with an IP address known to be used for phishing. For anything beyond, there is no other way but the deployment the Bitdefender software to all clients.
