tshemphill
Mar 01, 2021Aspirant
Bitdefender Total Security vs Netgear Armor
I happen to already have Bitdefender Total Security installed on one of my devices. The Nighthawk app doesn't recognize that it is already there. I tried over installing the armor link over what wa...
tshemphill
Mar 02, 2021Aspirant
It is a pre-existing Bitdefender license.
Christian_R wrote:Hello tshemphill,
Just to confirm, is you're Bitdefender Total Security a subscription purchased directly from Bitdefender? Or was Bitdefender Total Security installed after subscribing to NETGEAR Armor using one of the methods in the links below?
Christian
Christian_R
Mar 03, 2021NETGEAR Employee Retired
Hi tshemphill,
Thanks for confirming. I would recommend checking out the article below from Bitdefender.
https://www.bitdefender.com/consumer/support/answer/27900/
Christian
- tshemphillMar 05, 2021Aspirant
Basically one or the other. I presume the subscriptions are equivalent?
Christian_R wrote:Hi tshemphill,
Christian
- Christian_RMar 05, 2021NETGEAR Employee Retired
Hi tshemphill,
There are a few differences between Bitdefender Total Security and NETGEAR Armor. The chart in the article below outlines the differences between the 2 subscriptions.
Christian
