JohnC22
May 08, 2022Tutor
Bitdefender will not allow connection to router on my iPad
Bitdefender will not allow connection to AC 4000 router on my iPad. The vpn stops Nighthawk from connecting. When I pause the Bitdefender, Nighthawk works. When I unpause it, Nighthawk loses connecti...
May 09, 2022Guru - Experienced User
Ok, a little more clarity next time. AC4000 is a speed not a mode. Nighthawk is a router brand but not a model.
Your first description reads like you're pausing the router.
You also put, the vpn stops it from connecting.
Are you using a vpn?
Are you referring to netgear armor as bitdefender? that you're pausing/unpausing?
Are you using icloud relay? If so, disable it.
- JohnC22May 09, 2022Tutor
Thanks for your reply. I am a novice at this. I will try to clarify.
My router is. NETGEAR Nighthawk X6S AC 4000 Trii-band WiFi Router Model R8000P purchased in May 2019
i am not pausing the router. The router still works on all my devices including my iPad where the Nighthawk app is. The Nighthawk app will not connect to the router. When it ask for my admin password to connect, it will not accept it. The app connection just times out. I am using the correct password. When I pause the VPN the Nighthawk app connects to the router.
i am using a VPN. It is the VPN for NETGEAR that was with the NETGEAR Armor powered by Bitdefender. It was offered when I installed NETGEAR Armor powered by Bitdefender. So I installed it.
i don’t know if this is the correct terminology, however, my VPN in Settings became usable when I installed NETGEAR Armor powered by Bitdefender.I am pausing it on my iPad using the the toggle in my Settings app. My Nighthawk app will connect when the VPN is paused.
My iCloud private relay Beta version is toggled off
In my iPad settings Wi-Fi, the Private Wi-Fi address turned on. Limit IP address tracking is toggled on. There is no private relay toggle in my Wi-Fi settings.I hope this makes more sense.
Any suggestions would be appreciated. Thanks in advance.
- plemansMay 10, 2022Guru - Experienced User
So when your bitdefender vpn is disabled, you can use the app fine.
But with it enabled, the app doesn't work.
Just to clarify thats the only issue.
Everything else works fine and as it should?
- plemansMay 10, 2022Guru - Experienced Usermuch more clear explanation this time. Thanks!
