NeilAlanH
Feb 16, 2024Guide
BLOCKED websites!
I bought this router as an alternate choice for my cable company's router. all seemed fine at first, but then the router started blocking one of the websites my husband uses. When he tries to acces...
michaelkenward
Feb 17, 2024Guru - Experienced User
NeilAlanH wrote:
all seemed fine at first, but then the router started blocking one of the websites my husband uses. When he tries to access the website, a netgear screen pops up stating that the site is a potential threat.
What was that Netgear screen? What was the exact message.
If it isn't sensitive, can you tell us what the website was? Sometimes they have out of date security certificates that can throw some browsers into a tizzy.
Are you sure that the router is blocking this? Have you tried this in a different browser?
These days browsers can get picky about the security of the web addresses we throw at them. They will display some garbage about insecure, but there is often a "here lie demons" link somewhere on the page that lets you take your life in your hands and get at the site.
If this is a Netgear screen, then maybe your new router is being helpful and has turned on the free one-month trial of Armor that it uses to try to suck you into a subscription. You van just turn off Armor. For once, this is something most easily done with the Netgear App than a web browser and the graphical user interface (GUI).
Armor
Look at the Armor setting. If it is on, turn it off and ignore the doom and gloom warnings.
When I called netgear at first, they told me this was an issue with my virus program, but I called McAfee and that was untrue.
McAfee is not omniscient. It is just like anyone other business and will try to pass the buck back to your router. Did McAfee even try to diagnose what might be happening?
I tried downloading the nighthawk app so I could enter the URL on the THREATS page, but I could not login, and quite frankly, i did not want a free trial that would cost $100 per year after the trial was over (this is what I was told would happen when I was talking to the support agent).
I'm with you there. I don't need any security help fro Netgear and have never used Armor.
Did you fail in your attempts to download the Nighthawk App? Or did it fail when you started using it?
What was it that you could not login to? The app requires several stages when you start to use it: Wifi, Anywhere Access and finally the router. Once done you shouldn't need to keep doing that.
One other suggestion would be to login to the GUI and see what messages are saved in its logs.
Finally, the usual boilerplate questions to eliminate some of the more common issues that crop up here.
What firmware version do you have on the device?
A number is more useful than "the latest". There may be newer versions, or "hot fixes", that do not show up if you check for new firmware with an app or in the browser interface.
If there is one it might also help if you told people the make and model number of the modem/gateway/ONT that connects this router to the Internet. Is it, by any chance, also a router, with a set of LAN ports on the back?
I ask because a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
- NeilAlanHFeb 17, 2024Guide
the firmware version is 1.0.14.134; if it does need to be updated, how is that done?
- michaelkenwardFeb 18, 2024Guru - Experienced User
There is newer firmware for your device:
R6700AX Firmware Version 1.0.15.146 - NETGEAR Support
That has a list of bug fixes:
Bug Fixes:
- Fixes the issue where an Armor ping is lost.
- Fixes the issue where Armor activation fails.
- Fixes the issue where the security for the 2.4 GHz radio is not correctly applied in bridge mode.
- Fixes the issue where the remaining traffic volume is incorrectly reported when the traffic meter is set without a limit.
- Fixes the issue where a pop-up window unexpectedly displays after a timeout.
- Fixes the issue where IPv6 blocking does not work.
- Fixes multiple other minor bugs.
Looks like it might apply to your problems.
I am surprised that whoever you talked to at Netgear did not ask about the firmware. As I said before, this is one of the standard questions when troubleshooting.
That Release Note explains how to update the firmware. but here is a generic KnowledgeBase article:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
My instinct tells me that, even if the update does not mend the router, your problem has nothing to do with Armor.
