mschmid4
May 20, 2020Aspirant
Can Armor detect/alert/prevent VPN use?
I'm considering purchasing a Netgear router in hopes that the Armor service will work well for my needs. Can anyone tell me how it handles outbound VPNs? Can it detect if a device on the network is t...
Christian_R
May 26, 2020NETGEAR Employee Retired
Hello mschmid4,
Thank you for your interest! Armor should have no effect on VPN services nor will it monitor the type of traffic you've mentioned. It essentially notifies/prevents any malicious activity and vulnerabilities.
Christian
mschmid4
May 26, 2020Aspirant
Thanks for the response. I am sure it allows for VPNs just fine. I was more curious if it could detect them. Scenario being stopping kids from circumventing the parental controls.
- mschmid4Aug 27, 2020Aspirant
In case anyone is searching for this in the future, I did end up buying an Orbi router and signing up for Armor and have the answer. Armor does not detect VPN usage or report on it. Likewise, it is not able to block it.
