OrbiRocks
May 09, 2020Guide
Can't use Armor in AP Mode
I have a Orbi RBK23 system running in AP mode. I'm unable to access the Security Tab or enable Armor/Bitdefender on it when it is in the AP mode. How can I run Armor on an Orbi when in AP mode? ...
May 09, 2020Guru - Experienced User
https://kb.netgear.com/000061880/Does-Armor-work-when-my-Orbi-or-Nighthawk-router-is-in-AP-mode
It doesn't work when in ap mode.
You'd have to secure it the old fashioned way.
1. decent log in and password
2. wireless security.
3. smart internet browsing
4. computer/device security.
- OrbiRocksMay 09, 2020Guide
Seems a little short sighted to me. Why can't Netgear allow Armor work in AP mode?
- plemansMay 09, 2020Guru - Experienced User
because it ap mode, the primary router is doing all the routing/dhcp/nat/etc.
ap mode disables a lot of features and leaves the primary router running them
https://kb.netgear.com/000061277/Disabled-Features-on-the-Orbi-when-set-to-AP-Mode
