jf2186
Jan 14, 2023Tutor
cax30gateway port forward delete not working/if i factory reset do i lose NetgearArmor that i paid 4
so im sick and tired of this problem. I do not know much about how all of "this" works but it seems to be an xbox origin problem. anytime i have more than 1 xbox application running on my network it ...
Jay187
Jul 01, 2023Aspirant
I have the same exact problem… can’t get an open nat type for my xbox out of this thing … i added all the necessary ports and it never works. Did you find a resolution?
michaelkenward
Jul 01, 2023Guru - Experienced User
Are you sure this is "the same exact problem"? It doesn't look like it from what you have said.
The original message, which doesn't make much sense, says nothing about xbox or NAT. That comes up often, but not in this discussion.
Search - NETGEAR Communities – xbox nat
Then there is the fact that this conversation is now nearly 6 months old. You would do better to start your own message.
And do it in the right place. This area is for Netgear Armor. which almost certainly is not related to your problem.
If you do start your own conversation, pick the right place for it. You don't say which Netgear device you own, but if it is the cax30 of the original post, try here:
Cable Modems & Gateways - NETGEAR Communities
