T3chTr3kk3r
Jun 06, 2022Guide
Configuration issue detected - device security at risk
My wife & I both have the same brand of Android phones, and I've set up both of us with Armor Security, Bitdefender, etc. My wife's phone is the only one that gets this "Configuration issue detected"...
OP1Kanobi
Jun 08, 2022Initiate
Any luck ?
thewhiz
Not sure if this was the solution, but the error message is now far and few between.
I went into the Orbi APP and went into BATTERY and changed it to OPTIMIZED.
Also in ARMOR SECURITY changed the battery to UNRESTRICTED.
- OP1KanobiJun 08, 2022Initiate
Got an identical situation. Will try the same.
- rgdaveNov 30, 2022Aspirant
Did that work?
- T3chTr3kk3rMar 29, 2023Guide
Did this work for you?????????
- canah23Sep 14, 2023Aspirant
nothing is working for me! Brand New PC and Brand New Galaxy - advice?!
Tried this, but it did NOT stop the message from popping up. For a while, it was less frequent, but now it seems to pop up almost daily -- or at least it feels like it!
I have my apps for Armor Security and Orbi both set as "Unrestricted" for battery.Anyone else have any ideas???????
I'd had my apps for Orbi and Armor Security both set for "Unrestricted" -- but I'll try your idea of Orbi set at "Optimized" -- and I'll hope it works. This issue is driving me a bit bonkers, and I'm starting to seriously reconsider the wisdom of using Orbi and/or Armor Security !
