T3chTr3kk3r
Jun 06, 2022Guide
Configuration issue detected - device security at risk
My wife & I both have the same brand of Android phones, and I've set up both of us with Armor Security, Bitdefender, etc. My wife's phone is the only one that gets this "Configuration issue detected"...
thewhiz
Jun 08, 2022Initiate
Not sure if this was the solution, but the error message is now far and few between.
I went into the Orbi APP and went into BATTERY and changed it to OPTIMIZED.
Also in ARMOR SECURITY changed the battery to UNRESTRICTED.
OP1Kanobi
Got an identical situation. Will try the same.
- rgdaveNov 30, 2022Aspirant
Did that work?
- T3chTr3kk3rMar 29, 2023Guide
Did this work for you?????????
- canah23Sep 14, 2023Aspirant
nothing is working for me! Brand New PC and Brand New Galaxy - advice?!
- T3chTr3kk3rSep 14, 2023Guide
I'm using Netgear, Armor, and Bitdefender on 2 phone (1 fairly new Pixel, 1 higher-end Samsung), 2 Chromebooks (both less than 4 years old), 2 HP laptops (also less than 4 years old) running Windows ... and I still get the occasional problems as I described above. I've done no further efforts toward "fixes" since those I described in my earlier posts. I've also received zero input or feedback from Netgear, Armor, and Bitdefender ... but I'll admit, I haven't tried going directly to "tech support" for the issues because of what I've read in this thread and others. <sigh>
If you're reading this, and you're having problems like I described, please update on this thread if find something new to try, especially if you actually have any communications with tech support for Netgear, Armor, and/or Bitdefender.
